Dakota_Don
- Joined
- Mar 19, 2008
- Messages
- 200
- Reaction score
- 1
2000 stratus, the batt light comes and goes.. the alt was checked and ok, the batt tested ok, wiring looked ok, so far every thing looks good, charges 14.2 -14.5 volts with the dvom..I know the VR is in the pcm, but would that totaly stop charging/overcharging if the pcm was bad? also will the IAT/map sensor cause the light to go on off? No engine light, or codes, will a batt temp sensor do this as well, anyone have test info?
ty for your input
ty for your input
