Does 64 valiant have dash lights?
Mariyah
Member
Can't find them. The dash won't come off cause the wheel so I can't get a good look.
When I rotate the only switch I have only turns on the dome light.
You should have dash lights some times the head light switch part that works like a potentiometer, when you turn the head light switch just before the click that turns on the dome light is worn out, sounds like you need a new head light light switch.
