timk225
I originally had a problem with my 1973 Dusters' 225 pinging easily, even on 93 octane. I reduced the initial ignition timing to 3 degrees. Then more recently, I replaced the intake valve seals, 3 of them were cracked pretty good and were very old.
So a couple days ago, with the gas tank near empty, I decided to test the engine with 7 gallons of 87 octane, it shouldn't need more octane than that.
And over the last day or 2, if I'm near the car 10-20 minutes after driving it for a while, I can smell the gas fumes. Today I looked at the 350 Holleys' sight glass, and I could see the fuel bubbling in there with the engine turned off.
I never noticed this with 90 octane ethanol free or 93 octane gas. It is just the more volatile 87 octane not handling the engine heat as well?
