340dartsport73
I just bought it this weekend at mopars in the park. Any experience with it good/bad or is it just a wall hanger.. Bottom # is 5488 and the runners are #5497
I was thinking that I could build up the outsides of the runners and hog the insides out as needed.The DQ I bought was close by and I thought it was cool, so I bought it. Initially I planned on using for 340, but nowhere near enough meat on flanges for the larger ports on 340 gaskets.
It will be more "impactful" once it goes on the Commando.
Looking at that set up I cannot help but think that the back left pair of cylinders and the front right pair will run richer than the others mainly due to the fuel that finds itself on the manifold floor as it leaves the carb. I personally would be more inclined to try standard spacers on each opening. Fuel doesn't like a complicated path into the cylinder.I just bought it this weekend at mopars in the park. Any experience with it good/bad or is it just a wall hanger.. Bottom # is 5488 and the runners are #5497
we did similar with a w2 intake we used on a 360. worked a treat.I was thinking that I could build up the outsides of the runners and hog the insides out as needed.
