Does anyone know where to get this hose??
JamesRR
Nashville, TN
This hose is from a kelsey hayes set up I recently purchased. I am wanting to replace the hoses before install but can't seem to find a correct looking one online. Ive searched numerous 65-72 cars for these lines but what comes back is a female to female line. anyone have a part number out there for this?
Is the idea that the kelsey hayes caliper should have some sort of fitting/adapter so you can use the female to female?
Send member davescuda a pm I think he was/is selling the brackets for these lines, he may be able to help
That hose is nowhere close to a factory original hose.
It's completely wrong.
I suspect you don't even have the correct "Hard" lines on your caliper.
You can get the hard lines from Fine Lines, the correct repop hose brackets from the member that's mentioned in another reply, and then the correct rubber hose at the auto parts stores.
I use Rock Auto.
http://www.forabodiesonly.com/mopar/showthread.php?t=218827
Take a look at all the pictures in the above posting.
It will show you what calipers look like with all the factory hard lines, hose brackets, and rubber hose.
It will help you out.
I have been rebuilding these brake systems for the past 12 yeras to sell on eBay, and then quite a few members have bought from me off this site.
Good luck in your rebuilding.
I just suspect your just not that familiar what all these Kelsey Hayes brake parts look like.
Jim V.
