Does stroking have any influence on detonation, good or bad?
dibbons
La Paz, B.C.S., Mexico
Just wondering how stroking a 360 effects the chance of detonation, assuming compression ratio is the same between standard 360 and the 406? Does stroking have the same effect on more or less detonation tendencies on all motors? Thank you.
One could argue rod length at a given stroke...the stroke increase makes the existing rod shorter, the rod ratio gets lower...the dwell time at tdc is less as the rod gets shorter...runs away from detonation faster. Lol planting the seeds...
I've never heard anything about stroke having an effect, but bore size definitely does. Huge bore big blocks are very sensitive to detonation.
Stroking......or engines with a longer stroke than shorter make it easier to achieve higher compression ratios.
You are very close on this.
As the R/S ratio gets lower, all that beloved quench you worked so hard to achieve gets pissed away by the piston being pulled away from TDC much quicker.
The lower the R/S ratio, the MORE timing you need.
