Dogdish Hubcap Sizes
ethan santin
Buck eye jim you gotta go
Bay Area California
Hello FABO,
Does anybody know if factory dogdish hubcaps that belonged to a 14inch steel wheel would fit on a 15 inch steel wheel 63 series from wheel vintiques? Or do I need to get new ones?
Thank you.
The 13, 14 and 15 inch factory wheels all take the 9" hub cap.
Show us o photo of your cap.
It goes by the year not the diameter of the wheels.
B and C body 67 and back was 10”, 68 and newer was 9”.
did an A body ever get a 10” cap?
I dont know what year the wheels are. They where on my 72 duster but i dont know if the wheels originally came with the car
Are your 14" wheels small bolt pattern?
The chances are 99% that your a-body caps are the 9" version that will work on late model factory and aftermarket wheels. Lay a tape measure across the caps you have on the back side. Around nine inches, good to go. 10 inch, probably not.
I have 67 barracuda sbp caps off 14" wheels on my Lbp15x8 ramcharger rims. And they will work on the aftermarket wheels, too.
