Door adjustment on A body
sparkyct
Active Member
Stamford, CT
Just wondering if the door striker is adjustable on a '72 Swinger, or do I have to adjust the doors
Repair the door hinges first. in most cases the door will go back to factory position. Little or no further adjusting required.
Agree with all above. The striker is a weak area and can tear. Start with rebuilding hinges if you have door sag then make adjustments.
