I just hung my driver side door. Now I cant get it adjusted. Is there a trick or a sequence. Or is this a two man job? This is starting to piss me off.
I have found it is a two man job, with my 13 yr old son running the rachet.
Remove the striker from the door pillar, shut the door, pick it up about 3/16" higher than the 1/4 panel, while maintaining the distance along the rocker panels using paint sticks at the front of the door.
Tighten the bolts, fine tune the bolt adjustment.
It is a pain, because off all the adjustment on the hinges.
