Guillermo Vega
New Member
hello I have my 70 dart swinger and I can’t get the door to be aligned with quitar pannel sticks out a bit on both sides I’ve tried adjusting the striker but no luck
Exactly what i was thinking. Nice paint,but door alignment should have been done before paint in case striker plate needed modification. Sometimes loosening striker floppy loose and re-tightening will bring it in further.Try removing the striker pin completely and check how it fits. Once you are happy with that then you can reinstall and work from there. If your hinge pins are in good shape then it will swing in and line up great without the pin in place.
