Door cards wood trim
Mopar Momzee
Vacaville
I have a 1972 duster and the door cards have a vertical wood trim. I see they sell the door cards with the horizontal trim but haven’t seen the vertical.
First question has anyone ever removed it from old cards to new ones? Has anyone seen the cards for sale with the vertical trim? Picture attached. Thanks jesse
My '72 had them as well as the last '72 I robbed parts from. A88 on the fender tag is for the deluxe interior. These are the door panels off the parts car (no fender tag on that one):
I redid the back ones so I could get the seat in. See here: 1972 Duster, 340/4, black on black (the endgame)
The vinyl seems to be heat pressed to a thin layer of white foam-like fiber which gives it that little feeling of being soft. The lines in the vinyl pattern hold the vinyl and backing together. And that is glued to the hardboard with spray adhesive and isn't hard to peel off-at least on the older parts. I'll be doing the front ones eventually as (you have noticed) repros aren't available but I know going into it they won't be "nice". But I'll take functional for the time being.
