Door hinge bolt sealant?
Woodsman341
Columbia, SC
First, I'm not sure if this more of a chassis or interior question, but here goes...
I'll also be posting in other Mopar-centric places, but here's my question:
What specific sealant did Dodge put in the holes where the door hinges bolt on? That is, the holes in the chassis through which the hinge bolts pass have (or in my case, had) some sort of sealant to help keep the water from infiltrating the passenger compartment. Anyone know what it was, or a modern equivalent?
They used various seal material. Some used a spray foam type, some used a liquid rubber type.
It was just a small amount of seam sealer.
Really you can use whatever you are comfortable with. Some use just a dab of spray foam before they install the bolts. It keeps water out of the kick panel area.
