Serj22
So when I bought my 4 door dart, I asked the guy if it had any quirks, and he said the back left door lower hinge needed repair. I said - no big deal. Well - go to open door one day and the hinge collapsed into the door. The metal it was mounted to basically corroded and popped into the door in one piece. I had to unbolt the hinge from the B pillar to allow the door to close. It took a nice small chip of paint with it to. I was sad. But non-theless, he said the hinge needed to be re-welded. I should have expected it, I just didn't expect it that soon.
This is a 1968. I'm curious how much it would cost to fix? I would assume I'd need to have someone fabricate a whole new front piece of the door there? It's fine if they take out the paint there, because it's never visible unless the door is open. The problem is I don't know how to weld, or really work with metal for that matter. I'm just a stupid finish carpenter. How much would a repair like this run? Unless there's a fabo member in the bay area that could handle this? I got that green paper stuff with numbers and dead guys on it for compensation.
