own a 1968 Barracuda and I'm looking to change the door handles out. I have no idea whatsoever how to take the door panels off to access the door handles. Any information will help thank you
Remove your window roller upper.
Remove your door handle.
Remove your arm rest and base.
Remove your door lock push button thingy.
Carefully pry around the edges of the door card with a wide flat prying mechanism....like a putty knife and pop out the cross clips as you gently pull on the door card.
