Doug's d452 headers in abody?
440seven
Madison, MS
So before I buy them just wanting to make sure these fit the 440 in a duster. I see alot of folks talking about them but can't pull any info on this part #.
Application chart says B and E body. Good luck with that.
Yea I bought em. RRR is more than likely correct but I had a bunch of points at autozone and discount code. Figured if they didn't fit there are plenty of folks with B an E body around my town I can sell to. Still haven't installed tho, kids took over...
I could be wrong, but I thought the only headers that fit A body with a big block are the Shumacher tri-y? Otherwise you are stuck with fenderwell.
Wondering if you ever got these D452's to fit. I have a set here as well, for a 68 Dart / 440.
I bet you could get them to work with rack. The driver side had a tube right where the steering shaft was and if I recall one tube hit would hit somewhere else. They def will not work on stock setup without moving tubes
I bought a set of D452's from a friend for my Dart project. I'm nowhere near the point of trying to fit them yet. I'll certainly give it my best shot though and if it's just not doable I'll sell them again.
I did read another post where a fellow said that the D452's pretty much mirrored the TTIs. One would think that many people have tried to fit them.
