BigBlockMopar has a good point, but I'll add that it's easier to make adjustments on the pre-'73 K frame mounts than it is with the spool type mounts. There's very little you can do as far as moving the engine around with the spool mounts, there's almost nothing you can really do for shimming or adjusting them like you can with the early biscuit style mounts. And of course it depends on your set up and other accessories. Between my spool mount K, oversize torsion bars, road race pan etc there's no where to go, everything is fighting for clearance.
The modification for the Z-bar is the same as for the TTI's, you can use their diagram
