Drag link/steering link 72 Duster
oldirish
Georgia
I converted my 72 duster to power steering which needed to different loan arm. Now the steering link doesn't work. I've seen a lot of posts on this subject
I can't find the part number for the 73-76 steering drag bar. I also don't know if I'll need to change the tie rods.
Any advice or help would be appreciated.
The tie rods and sleeves are interchangeable. To my knowledge no 73-76 center link is reproduced. Ithink I was able to use the 73-76 power steering idler arm on my 68 gts manual steering box. You will need to verify the pitman arm interchangeability.
The early power steering used the same pitman arm as the manual box. You went with a large sector box which will require the '73-up link, which is only available used. You will also need a '73-76 idler arm. Tie rods and ends will work.
