[FOR SALE] Dragster For Sale
rampage340
clearwater Fl
This car won Gainesville, Div. 2 Top Dragster in 2007
Plus many bracket races. Everything in Excellent Condition.
2002 - 235", John Gifford HardTail powder coated chassis
NHRA Cert. 6/09 - 6 Sec. or slower
Cage is 23”
Peddles Adjust, will fit large & tall driver
Stroud - Pull-up Seat Belts
Stroud Parachute
16 volt battery, plus 16 volt Schumacher Battery charger
16 volt Alternator
K & R pro-cube crossover delay box
New 16x16, Weld wheels with 34.5 x 17 x 16 Good Years
MSD Ignition
B & M shifter with nitrogen bottle controlled shift solenoid
Auto Meter Gauges
BG Fuel pump
Alum. radiator and fan
Ceramic Coated Down sweep Headers
Engine Diaper
MW Alum. Rear end, Strange Axles, and Aerospace Components
Brakes
620 ci BBC Dart Block, New create motor, 1000 hp, Less than 40 runs
1250 Holley Dominator Gas Carb.
Engine upgrades: Billet Crank, Pistons & Rods, Cam belt drive,
4/7 swap Cam, Crank Trigger Ignition, Super Damper, MSD dist.,
Vacuum pump,
Brodix Alum. heads with Jesel shaft rockers, HD springs, Red Zone
lifters
Dedenbear -nitrogen bottle controlled throttle stop
Runs easy 4.80 @ 145. 1/8 mile and easy 7.65 @ 175 in 1/4
New TCI 2 speed PG Trans. Pro Glide with 180 straight cut gears,
Alum.Trans cooler, 9.5 TCI Pro-x Converter, SFI flex plate, Less than 40
runs
Complete, Ready to run race car, only $23,995.00
Package Deal available with Trailer.$29,995.00
