[WANTED] Drip Rails 1974 duster
George L
Mount Hope Ontario
Rating - 0%
0   0   0
I’m looking for
drip Rails
For a 74 duster
Not the moldings
Anyone know where these can be purchased or does anyone have a complete set ( Drivers and Passenger side)
Thanks in advance
Do you mean the part welded on the body, or what screws on under it to hold the weather seal? If the latter -I have a set up in the rafters of the garage.
I think they are in pretty good shape. I know one of the little end plates came off, but I have it...somewhere. If I have time, I will pull them down later today and check them and see if I can find the little end piece.
Don't think they weigh much, but they are one long, curved piece. Shipping from PA could be a killer. Hopefully someone in Canada has them...
these are the pieces .
the roof skin is welded to them and the weather stripping attaches to them
These look not bad except there rotted out close to the edges and they are paper thin . so welding is just going to melt them
Ok, not what I have. Is it just on the back part that is a problem? I would just piece in those areas with a small donor section. Probably best to check for a part out thread and see if someone can cut out a chunk with exactly what you need.
