Drive shaft length specs
I'll just say... be careful....
That's another one that someone REALLY needs to look it over because there's some bad info in it. Been up at moparts for a few years.
You are correct. I can guarantee the spec on the 68 Barracuda with a 727 and 8-3/4 rear is wrong. It shows a longer driveshaft (albeit by only a couple tenths) with a 727 trans. and 8-3/4 than it shows with a 904 trans. Should be 3 to 3-1/2" shorter with a 727
i have wondered what the correct driveshaft length is supposed to be in my car.
68 dart ....it had a 904 and 7 1/4
i recently changed it to an 833 OD with the same rear end and i used the same driveshaft but changed to slip yoke ....it runs and drives but i think it looks to "tight" not much slip yoke visable when not in motion and when removing the driveshaft ...it takes a little jimmying to get it out. :happy1:
I like getting new shafts made for my cars and trucks after tweaking suspensions and doing tranny and other driveline swaps / work. Those variables put the only truly correct answer on the tape measure in your hand. Best length gives minimal slip yoke clearance of about 1/4 to a 1/2 inch at full droop.
I know this is an old post . but after looking at it I was just wondering what a Dana 60 in a 71 dart with a 904 length is ??? I guess I will find out when I have on build for it.
Just opened up my browser, and went to forabodiesonly to post a question thread. I didn't even get a chance, because you answered it. The other forums don't have resident psychics. Thank you so much for the post. By the way, what's the weather for the next week ? any choice numbers for lottery predictions ?
So theoretically, if I have 1975 slant 6 duster, 904 w/ a 7 1/4, and I have a 1969 barracuda 340 727 w/ a 8 3/4, and I want the 69 drive train in the 75. I can swap the drive shaft, and rear into the duster first. Allowing me to drive that slant 6 / 904 combo, until I'm ready to do the engine, and trans, and all the parts will work properly.
The yoke for a 904 trans. is different than a 727 so it won't be a direct swap. It'd surprise me if the driveshaft length is correct also. A 904 is about 3" shorter than a 727 and a 8-3/4 is longer (yoke to axle centerline) than a 7-1/4... You'd have to be real lucky for the driveshaft to be the right length.
I like what fishy68 said, and his info. I have a D.S. from a 727/8.75 combo that I drove for years, and I have another combo from a 904/7.25 that ran really smooth. So I should forget the yoke, and measure the shaft lengths. I will say though the 904/7.25 combo is much smaller in diameter, and tapered. So the one shaft is beefy, while the other has a taper, which theoretically should make it strong too.
I hate theoretics...
Earlier this year I needed to shorten my driveshaft after putting in an 8.75 to replace the noisy 7.25. I did some measuring and decided it needed to be shortened about 2".
While looking through my factory shop manual I discovered they had the driveshaft dimensions listed for all the various transmission/axle combinations. The book confirmed my measurements and said that it needed to be cut just a fraction over 2". It was actually listed in thousands, not fractions, but I don't remember the actual number right now.
So check out your OE shop manual. It just might have the info you're looking for.
This would be a perfect time and place to start our own verification of that list. Everybody should list their combo and car and give the center to center driveshaft measurement.
