Driveline Vibration
ldtc
Member
Have Driveline Vibration About 60mph Tci 727 Tci Conv.b&m Flexplate Balanced Steel Driveshaft
Check your u joints that they're not siezing up also that the bolts are tight at the pinion shaft u joint clamps. When you notice the vibration carefully shift to neutral and see if vibration goes away as engine idles down. You could also have a brake drum whoes weights have fallen off. Any number of things.
Terry
