drivers fender radio antenna removal
There is a special tool that fits in the notches, I've had good luck using a pair of needle nose pliers tips down each in a notch and twist with a screwdriver. Or if your going to replace it use vise grips to get it off. Either way spray it with some lube first.
It's a secret....
If we told you, we'd have to kill you...
And we don't want to do that...
