Driveshaft Question?
Moparornocar51
Austria
Hi Fabo members, i have a trans 904 26spline i believe and a 7 1/4 rear axle, i want to change my axle into a 8 3/4 axle, i knew i would have to shorten my driveshaft, but i want to buy a new one from dennys driveshaft!
See here
http://www.dennysdriveshaft.com/p29...t6_aluminum_driveshaft_high_speed_balanc.html
So my problem is that i dont have the 8 3/4 axle here now as im from austria i have to order and find that axle first, so guys im still searching if u have one let me knew please...and i cant measure wich driveshaft i need now wich length and so on...My car is a 72 plymouth valiant
Maybe anyone knews the length allready and the details wich i have to tell the shop at dennys driveshafts?
That would be really great, thx Guys
Peter
Call Joel at Allstate Driveshaft in Yucca Valley, CA (760) 228-1127
Why are you going aluminum?
Dart/Scamp with a 904/8.75 set up should be right at 51"
Thanks why not aluminum? I thought because of the less weight and i think its a good one, or would you prefer a steel one?
I was calling denys driveshaft and he said its not funny when i will lose alot of money just 51" is not enuf he had many problems about that i want to order this one
http://www.dennysdriveshaft.com/p28..._duty_steel_driveshaft_high_speed_balanc.html
with the 7290 rear pinion yoke on the 8 3/4 rear end and he said, it would be good when someone did that allready and can give me his name and surname so he can look at the computer what he ordered, maybe some of you guys can help me thanks alot!!
Peter
Then you need to measure.
51.96" is what the service manual calls for with 904 and 8.75 rear.
crackedback,
Another drive drive shaft. We are moving to an a727 /8 3/4 from a /6 902/7 1/4 i think. I was told to cut 2.25 inches off of it.
Good or bad info ?
Thanks
Ian.
Thanks guys but i think i really have to wait for the 8 3/4 rear end first and measure it then
