Driveshaft
I have one since the previous guy did not show up.
do you know the length you are looking for?
I am in CT and not going to VA till turkey-day
It needs to be 45" center of rear u-joint to center of front joint...I don't need the slip yoke but if yours is still attached that's ok....must not be bent..if there is any crease in the tube at all it is bent....I already have that!
Ok, Since there is so much confusion on this subject I am posting 3 pictures of the drive shaft I need...45" from u-joint center to center, taper at both ends..........Hopefully this should clear up ANY and all questions........................maybe..
