nothingbutdarts
I have the plug for the ign box and most of the old wiring harness. What wire needs 12volts to power the box? I plan on using an on/off switch and starter button that I already have.
http://www.forabodiesonly.com/mopar/showthread.php?t=240591&highlight=pin+wiring
See post 3, the second wiring diaghram with the 4 pin. The top wiring area where the splice/existing wire & new wire is the place you would run your on/off switch to. (12 volts).
Now for the starter button, you will want to turn on the starter with it, but somehow you also need to feed a full 12 volts to the + side of the coil while (cranking only) then let the existing wiring run the coil when not in the (cranking mode)
