drum to disc conversion...1976 Dart Lite
Backtobasics
Kansas City, KS
I am doing some homework before I bring the car home. 1976 Dart Lite, Manual EVERYTHING (brakes, steering, non ac)
He says it's drums.
I have looked around, and there seems to be little for 73-76 Dart for conversions.
What is recommended. I am not in range of spending 1050 (MPower) for front kit..... I checked www.scarebird.com, but they only service up to 72. It seems that most of the 73-76 had discs already. So am I stuck looking for a 73-76 to convert?
You should have large ball joint uppers on the car. If you do, you need the spindles out from a 73-76 a body or you could use F body stuff as well. Get a 73-76 disk proportioning valve, master and new lines and you're set to go.
http://www.moparaction.com/Tech/archive/disc-main.html
Basically the same swap as described in the mopar action article.
Check the ball joint castle nut. If it's a 13/16 or 7/8 you have BBJ and don';t need the uppers control arms for the swap. SBJ has a 5/8 nut, IIRC.
I might have a set of spindles on out for sale.
So swap the spindles, if I have the big ball joints, and then I can use the stock caliper rotors, and caliper adapters, for the 73-76 disc setup?
Do I need a caliper bracket, and does your spindles have that.
Count me interested!
