Drum to Disc Conversion
stokey04964
Rangeley
Going to Disc from Drums on the Demon. Where they were 9's do I need to change the Master Cylinder? If so the Propertioning valve as well?? Thanks
Yes to you need to change the master cylinder and prop valve as well. Your also need to change out your spindles.
yeah got the brakes on there just was not sure about the master cylinder. Thanks for the info!
