Brake Pedal Stiffens Until I Start Bleeding the Front Brakes
So the safety switch would ground and turn on the warning light I assume. So a test light connected between pos and the switch, the test light would light if it was grounded.
You mean if it was leaking at the prop valve it would trigger the warning light via grounding? Will check into that
