Hi I'm going to swap my front drumbrakes to discs using a kit from cpp, and I'm wondering if I could use my old power brake booster that I used for the drums on discs or if I have to buy a new one to get this to work?
The booster should be fine prob have to change the master and add a proportional valve though.
Any disc/drum proportioning/metering vave assy. for your body or similar(E-body) will be fine. Look for one in the best physical condition/situation(covered-dry-assembled).Okay! thanx! Can I use any junkyard proportional valve? Or does it have to be any specific?
