Hello,
I'm installing a 383 in my dart and would like to run dedicated feeds to each carb bowl from the regulator. The problem I'm running in to is I also need a bypass/return and I don't have enough ports. What do you guys do in this situation? I was thinking about a fender mounted with the bypass and a carb mounted deadhead.... thoughts???
