You'll be OK for coil bind with the single spring IF you install it at 1.7. But just because the spec sheet for the spring says 1.7, does not mean it will install there. That depends on the retainers and valve. Stock retainers & valves install at around 1.650" IIRC. If that was the case, then the compressed height at max lift would be past coil bind so that does not work. You either change retainers or locks, or deepen the valve spring pocket , or a bit of both.
BTW, IMHO, .035" is a bit close on coil bind. I'd shoot for .060".
You are not going to find a multi groove keeper in .050, -030 and -060 and+ 050 only available for single grove style valves.
Yes.
But you must have a single groove valve stem to us it. stock chry valves are 2 or 3 grove valve and keeper style.
In other words, you would need to buy all new valves to go with a single groove lock/keeper
Nope you have to compress the spring to brake loose the retainer from the locks.... then you will know.
They may be single grooves.
got to pull them to know.
OH MY GAWD
Sorry never have replaced springs. Hopefully someday you will need to ask about pulling a VP44 out of a 24v and I can make fun of you. The manufacturers of this stuff don’t make it easy to figure this out. I can buy a whole kit from every cam manufacturer with locks, springs retainers etc, and they don’t even tell you how many grooves the locks have...
Trying to learn...
