[Found!] DUEL FEED FUEL LINE
I have one but need model # since there are several different ones. Mine is $10.
I have this one which should fit. The specs on mine match length and thread on the Holley. Mine is different as seen in pics. $10 + frt. If it doesn't fit tell me and you can keep it and I will refund part cost. I have seen some from Mr Gasket that have a thread adapter but they dont give the flare size, hence the reason for the brass adapters. Mine does not have a provision for a gauge. This matches all dimensions for the one that Holley recommends for your carb. Holley 34-150 Fuel Line
this is what came with it yours looks like the same threads do you have paypal im in MILTON PA 17847
That is the adapter that screws into the fuel bowls that the hard line attaches to. As I said, check your PM for my email address & send me a picture of what you have. I can probably help you out, but I need good clear pictures to make sure of what part(s) you need.
