sydcuda
I've just installed a disc brake kit with 12 inch rotors and PBR 2 piston calipers (as an aside, PBR are an Aust. company and OEM suppliers to GM and Ford in US, I believe - Baer brakes also use their calipers). Anyway, as mounted, the rotors are about 1 inch further out from the hub than the stock rotors. You can see from the pic below that the dust covers would pretty much be useless in performing their function. Would do you think - do I really need them, or should I just go without the dust covers?
