Duster 340 Leaf Spring Rebuild
  • Thread starter Deleted member 9923
  • Start date
D
Deleted member 9923
Guest
I am rebuilding a set of rear springs - I have them completely disassembled, including the bushings. A rebuild kit is on the way from Year One, and bushings from ClassicIndustries. But I need some help finding the correct center pins. The Duster had a 5/16 diameter bolt, with a half inch round head to center the axle housing on the spring. I haven't found a source yet. Autozone and Advanced sell some hex head center pins, but the correct ones are round, and the round ones will of course fit into the round hole in the axle assy better than a hex. I could of course clean up the threads on these, clamp the leaves together and reinstall the old pin but prefer a new (strong) pin.
