duster 727 update and help needed
ValerianMagnum
the little car that could
montreal , canada
hi Guys , new trans works ok in 1st , wheels are turning but the 3rd manual 'stick-shift'and reverse gear is not working when we put the gears into them ...what can it be ? 727 with red clutches and new stall converter , kickdown system , not reverse valve body
Do you have a race shifter in the car with a cable ? And if you do , do you the correct shifter arm that came with the shifter on the transmission and cable adjusted correctly ?
So u didn’t know how to read the dip stick? Glad u had help. Kim
My friend put 6 liters + fillled up the torque..but the 2-1 shift wasnt working manualy and the reverse too , was only working on Drive , did some quick research and after 3 more litres it was good , we were scared at first !
Wondering if we can go just drive it as is , looks to shift alright now on the jack stands , was thinking to drive it a bit in the streets and bring it to a ttans shop to adjust the bands and install my transgo shift kit
