Duster brake problem
MR4V
Brisbane Australia
Having a problem to identify these brakes.
The Duster is a factory 340 with drums all around they look to be front 11" fined drums with the marking of 10.90.
The wheel cylinders have a part number of 29552C & I can not find these on the Rockauto web site nor can I find the rear wheel cylinder's & there part number is 3461776.
Also if a member can help with the standard factory master cylinder part number for these it would be of great help, as if I order the wrong ones it's a bit hard to send them back from Oz.
Cheers
The 10.9 is the maximum diameter the drum can be machined to. That is 11 inch brakes. I've heard of 11 inch brakes on a-body listed police/taxi but never seen them on a car. I suspect you have the large lug pattern too. Maybe a previous owner installed B-body brakes on that car.
