[SOLD] Duster/Dart interior parts
dpmalibu
Hatboro,PA
1) Column shift steering column missing shifter lever/arm $30
2) green lower rear interior panels $30pr.
3) Gauge cluster (a little rough but still works) $25
4) white door handle bezel/trim $10
5) window cranks $10
6) Black A-pillar trim (driver side has a couple of screw holes in it from tach being screwed to it) $15
7) Black trim that goes over door opening holds healiner in on sides $15
8) black steering column strim (located under steering column) Has a small corner piece cut off. Good for a driver quality car $10
9) (2) ashtrays (1) white (1) black $10 ea.
10) woodgrain glove box door In very good shape $15
11) gas pedal $15
12) emergency brake mechanism $15
located in Hatboro,Pa
Still available:
:cool: black steering column strim (located under steering column) Has a small corner piece cut off. Good for a driver quality car $10
11) gas pedal $15
Yes but there might possibly be one person in front of you. I will let you know if he still wants them or not.
