[WANTED] Duster/Demon/Dart sport Driveshaft for 8.75 to A833/A904
Cuprum-74
Moparus Fanaticus
Utah
Figured I ask around before sinking money into a custom build order.
Trans yoke not needed.
I believe the shaft itself is 49.27 C-C of u-joint.
7260 or 7290..or 1350 joint?
To my recollection... Only 66/67 had a833 with a smaller 904 tail spline.
833- 48 1/2
727 - 45 1/2
904- 49 1/4
49 1/4 fits but its tight if the car is factory ride height. lifted a little you'll be OK. The large yoke adds to the length when used.
Sorry should've clarified,
7260.
The u-joint cap size is roughly 1.078.
No tabs and the measurement between the flats is roughly 2.125 inches across (micrometer says 2.1256, but close enough)
These u-joints I have fit perfectly: More Information for MOOG 246
Correction it's not 49.27, according to a chart I found on this site:
---S/N --------------Dia.---Length---Trans.-----Diff.----Eng.-------------Model.
2996157 1972 ----3.25.---48.89---904/230---8-3/4---225 318-------Duster Demon
2883760 1970-72--2.75.---48.96---833 -------8-3/4---340------------Duster Demon
2883760 1970-72--2.75.---48.96---904--------8-3/4---198 225 318--Duster Demon
