Duster fiberglass doors
71ChargerSE
NRH, TX
Hey all, I'm working on a '69 Valiant and I'm looking for fiberglass doors. I found Duster doors and I was wondering if they'll work? I know they don't have the upper loop, but I believe I found a way to get around that.
Thanks!
I'll be doing the same thing soon. My plan was to fab an aluminum frame to duplicate the steel, and 'glass mounting points inside the window channel for it.
Ok cool, I thought they were pretty close. I am planning on Lexan windows and considering aluminum bar to make the upper frame.
No,the duster doesn't have the sedan frame around for the glass. Modifying as above sounds like a PITA *** and is a possibility of not working. If you get some free doors then all you will have is time in them.
