tnts72
Have a power steering pump / box / mounting brackets - can include a pitman arm, but it is the top down version which came on my manual box. Power box had a little slop, probably would need rebuilt if someone wanted to put it back into service. Pump worked fine, no noises or leaks - does have two factory shim washers in the pressure valve - pump it down mod. made the slop a bit more noticeable, which is why I went manual steering.
$150 come and pick it up will be a heavy one to ship!
Power Steering column to box coupler - stamped metal cover is a bit mangled but useable and the springwire (Ebay) keeps everything in place. Includes everything pictured
$40 shipped
U bolts from ESPO, had to get a longer set when I installed the lowering blocks, few nicks and dings from installation and removal - can run a die over them before shipping if buyer would like. Nuts and washers included.
$20 shipped
Dana 60 axles 29-5/8" long I believe, 5 on 5 pattern 30 spline. Could be a set to get cut down and resplined if narrowing a 8 3/4 or Dana 60.
$100 pick them up
Mini starter / Black steering wheel are about the only items I would be interested in trading for at this time.
Or a Plymouth grille emblem - yeah right I know!
$40 shipped
$20 shipped
$100 pick them up
