troop
I got the channel guide seals from Dantes for the pop out windows on my 72 Duster, and was told that they would need to be fabricated to fit the hinge guide on the Duster. I was told it was easy but not how to do it. I am told the guide is made for a 66-7- B body but will work in the Duster with some slight fabrication.
other than just needing to be cut to length does anyone know what other fabrication if any is needed. any help would be appreciated. also does anyone know where to get the foam seal that rides on the outer edge of the pop out windows?
Tony
Tony
