Dyno’d it today
Dose she get hot?
What radiator, thermostat or plate?
What fan?
I'm sure if your not tubbed, it's more than enough to destroy the rubber at will.
It just has a champion radiator a thermostat and twin fans just the summit brand. I don’t remember which ones but they cool it well, it doesn’t get hot at all. I put in a switch to turn the fans on manually just in case but I’ve never needed to. And it is mini tubbed with 325/15 Mickey Thompson drag radials stretch on a 12x15 draglite.
Your right dyers asks what boost you plan on running but depending on your motors breath ability you may end up with a little more or a little less. My pulleys were ordered for 8lbs of boost but I got 5lbs. But 5lbs of boost on my dart is more than enough for what I do with it.
So your about 390-400 ish ci with the stroke and bore?
5Lbs on street tires is loads of fun! Add a 4 speed and a 4:10 and you are getting a full body workout when the pedal gets mashed!!!!!
Yep, it’s a 4speed. I think with the 40 overbore it turns out to be 392ci.
