e-brake levers needed
dusterny
Penn Yan NY
I need emergency levers for 10" drum brakes for duster. Ineed the pin type used on rear brake shoe. I think 11" will fit also. If I can't get a set I can get by with driver side.
I might have one, but I have to scrounge around and check. I have an old 7 1/4 axle I can't remember if the brakes are on it or not. You say that you need the lever with the pin that attaches to the shoe. Do you need the bracket that goes to both shoes also?
