E-core coil mount
mopowers
West Sacramento, CA
Can anyone share a picture of how they mounted their e-core coil to the stock location on the back of a small block intake manifold?
Does anyone make a bracket for this?
Thanks!
Bringing this back from the dead...because I was going to ask the same question. Anyone?
Not sure if you are talking about one of those "cube shaped" E-coils, but here is how I mounted my 45,000V Beer Can style coil on the back of my Airgap manifold if this helps - it's Oil filled so it needs to hang vertically. (Homemade bracket)
This probably isn't any help, but I'll show it anyway.
It is the tall bracket like used on trucks and is mounted on the same bolt as the power brake booster support.
I opted for this place to keep it all out of the heat and to give room next to my distributor for my OD and lockup pressure switches and distributor bracket bolt.
I'll get you a picture and a PN once I get home, but I bought one that comes with an L shaped bracket already riveted to it. Bolted right down to the intake and is solid as a rock..
