Dwell in degrees is rediculous. Time in degrees varies with RPM, so the balast resistor is added as a cheap fix. Then came electronics, but Mopar kept it cheap and simple and did not implement dwell control. HEI controls dwell in an analog fashion, to charge the coil based on prior ignition event. Micro controllers do a better job, because controlling time requires logical adjustments to hit the ever changing target.
Most think in terms of R C time constant, but for inductors it is L/R. The maxium current is V/R. For a 0.32 Ohm coil at 13.8V, the maximum current could reach 43A. However the coil is likely able to tolerate 5 to 7A long term. Ignitions without balast must accurately limit the charge time to limit the current, or use the switch in the active mode. Most use both, but limit the active mode , because it heats the switch, just like a balast gets hot. Active dwell control has the most difficulty at low RPM. An example is at 800 RPM, there is about 19mS of available time for coil charge and ignition. If it takes 3mS to charge the coil, that must be done just before use in a predictive manner. The solution is to charge early, to accomodate timing advance ramp, and RPM fluctuations on take off. When charging early the desired coil current is held to the desired value. There are ways to PWM control current to that reduce power dissipated in switch.
V8 and one coil is a compromise at high RPM. While MSD CDI provides higher peak energy, the spark duration is very short. The modern solution is coil per plug.
