[Found!] Early A /6 rotating gas pedal assy
petty437
Kent, Ohio
I'm looking for the rotating rod, bell crank & inside floor mounting bracket. I need to do some reengineering for an Offy intake I'm looking to install. (yes, I know I could go with a cable setup, but I like a challenge!! Thanks!
If you're in no hurry, I will be taking one off my Valiant later this winter to install a cable setup for a 4-bbl.
I “think” I have everything from the pedal to the rod that attaches to tge carb. I will have to find it all if interested
I have a setup from a 65 Valiant /6. I’ll need to dig it out of my parts pile. Swapping in a 318 so I don’t need it anymore.
Thanks for reminding me
That picture is of the kickdown bracket that bolts ti the driver’s side head at the rear on a V8
I’ll dig mine out when I get home today.
Found the parts. You need all of this? The bottom of the gas pedal where it bolts to floor is rusted out. Let me know what you think
