breakstuff
Early A headers. These headers are hooker supercomps 2" primary, 4" collector fenderwell exit headers that have been modified to fit an RB engine into a 65 dart. They dump out between the rocker panel and frame rail. Missing one slip on collector, Summit has replacements. Will not fit a car with inner fenderwells, and have only been tested with RB (440) engine for fitting. I have no idea if they will work with a low deck. need to use an offset master cylinder adapter $200.
360 (externally balanced) flywheel. $80
center console Fiberglass part is nice, the door is OK. Shfter plate is slightly modified to use an aftermarket shifter, meaning the P R N 3 2 1 lens is part of the console. $80.
I would prefer not to ship these things, I will be bringing them to Norwalk on the 11th 12th 13th. otherwise they will be pick up in South east Michigan near Adrian.
