Valiant Ef4t
Member
I am installing a 1990 Dodge Power Ram stick 360 in a 1965 Valiant 200 2 door . It will also be a 4 speed. Is the harmonic balancer an issue, can a 273 balancer and timing cover be swapped? And are headers available for power steering option? Is the truck flywheel and clutch a good setup? I also own a 1965 Signet, factory 273 235HP, 4 speed, and once owned a 1965 100 with 273, 235 HP,4 Speed, sure grip, 16:1 steering, HD suspension. The 200 is a tribute to my earlier 100, with upgrades of 8.75 rear end and disc brakes. One more question, is the 1970s electronic distributor an adequate for the 360? Thanks.
