[WANTED] Early A body Ignition switch and doors locks keyed alike and trunk lock
Federalsburg, Md.
Rating - 0%
0   0   0
I have a 61 Dodge lancer that I am looking for a matched set of locks for. If you have an ignition and door lock set that use the same key and a trunk lock with key and installation clip and rod I would be interested. I believe that these are similar for many years. Please let me know what you have.
I have door locks that you could get rekeyed to match your ignition but no set all matched. That's a tough order to fill. Generally you can use any dash mounted ignition thru '68. While some years have extra tabs on the backside, your early plug will go right on leaving the extra terminals exposed and function properly. Some? '69 ignitions have a larger threaded barrel/retaining collar and those won't mount up (but will plug in).
I actually might have the ign and door locks with a key. Have a pick of the ign that you need?
I have these.
$70 shipped?
Now I have to find them again!
