[FOR SALE] Early A body Mechanical parts at Carlisle
FWDLK Frank
Baltimore
Hello, I'm at spots IA 26-28 at Carlisle this weekend. Here's what I have for sale...
D64 intake with carbs $1600
D66 intake with carbs $1400
Early A V8 throttle bracket 25$
A body 833OD with ITM shifter and rods $350
Slant OD bell housing $125
Early A K member $50
Early A slant ps pump $50
Early A AC lines, receiver drier $120
Early A slant AC carb $20
Early A AC condenser $50
9" rear brake parts (hardware, wheel cylinders, hose $50
65 cross member with correct 2 stud mount $180
66 cross member with no mount $50
65 273 heads $50
Small block adjustable valve train $125
Early A 273/318 small block motor mounts $145/pr
273 timing cover $80
Used std 273 hi po pistons and rods $100.
Sent from AOL on Android
Photos attached.
Early A body V8 throttle cable $125
7.25 5 on 4" with 10" brakes $50
65 273 heads $50
Hi Frank - I’ll see you tomorrow- put the early A V8 throttle cable aside - consider it sold
